Revit elevation material realistic/consistent color not working correctly in 2D, but it is correct in 3D view. How to fix this problem.?
The correct color shall be like this. It is showing on 3D elevation.
But becomes like this in 2D elevation :
No material showing up & color is wrong.
Please help me. Thanks!
Gelöst! Gehe zur Lösung
Gelöst von wjxu55. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Realistic and Consistence Colors are not the same. The Material's Appearance Tab settings are what control how the Material looks in Realistic. The Material's Graphic Tab settings are what control how the Material looks in Consistent Colors. In your case, the bottom screenshot looks more like a Shaded Visual Style with Light Settings jacked up. If so, you can adjust the Light settings under the View's Graphic Display Options.
Thanks for all the above.
It is problem with the Phase filter, set to "show complete". Color show correctly.
