Revit element material locked
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
maria6EKZF
770 Aufrufe, 6 Antworten
I am unable to change the material assigned to an element in Revit. The material block is greyed out and I want to change it from what it is to something else. Please assist.
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: maria6EKZF
It's Associated to a Global Parameter. Press the "back/forth" arrows to find out what it's Associated to and change it or disassociate it.
Nachricht 3 von 7
It's not locked but associated to a material parameter and it's a hgood thing. You don't need to disassociate it, just open family type properties to change the material.  It's done that way so that you can change the material directly in project without having to open the family every time.
Nachricht 4 von 7
als Antwort auf: barthbradley
HUH? Hardware Category?
That make sense to you, @ToanDN?
Nachricht 5 von 7
Why not?
Nachricht 6 von 7
als Antwort auf: ToanDN
Thx.
Nachricht 7 von 7
maria6EKZF
That worked, thank you so much.
