Revit dynamo Boundingbox
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
nagybela2000
541 Aufrufe, 4 Antworten
Hi there, I have a problem where I want to create a bounding rectangle around the doors in a Revit file. I’ve more or less managed to do that, but unfortunately, the coordinate system doesn’t match. Could you possibly help with what might be worth doing? Additionally, these solids are not being placed in Revit as generic models.
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
ridantuo
als Antwort auf: nagybela2000
If I understand correctly you want to bounding box to be rotated according to the door family? I dabble with Dynamo so I am not the best one to guide you but..
I think it is currently using the "project" coordinates and you need to have it use the object coordinates, so use one of the other nodes. (Proper Dynamo professional talk am I right? :strahlendes_Gesicht_mit_lächelnden_Augen:)
The two nodes in the attached pic seemed to rotate according to the object.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Nachricht 3 von 5
handjonathan
Hi @nagybela2000
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ridantuo helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 5
nagybela2000
als Antwort auf: handjonathan
I managed to solve it, thank you for your help. My next question is how can I reduce the size of these rectangular prisms by 1-1-1 cm?
Nachricht 5 von 5
nagybela2000
Could you help me the next step?
