Revit - drawing sheet title offset to the left - text not in center like normal
2 ANTWORTEN 2
Nachricht 1 von 3
340 Aufrufe, 2 Antworten
How can this be fixed - cannot read sheet title because off center to my right
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
That seems Windows Personalisation issue...
you may try to change windows themes .
which windows version you are using?
Corsten
Building Designer
Nachricht 3 von 3
als Antwort auf: Corsten.Au
Hi Ganesh,
Got your message.
Am using the latest edition of 64 bit - Windows 10.
Let me correct myself - the Revit drawing sheet tile is off to my Right as I
see the screen, mostly hidden behind the "Type a Keyword or Phrase" window.
See attached copy of error.
Thank you,
marcus swed
