REVIT Drafting View Coordination
3 ANTWORTEN 3
Nachricht 1 von 4
345 Aufrufe, 3 Antworten
Hello Everyone,
I am trying to do a section cut through a corridor and wanted to draw in elements from fire suppression (hangers and sprinkler head) in the section view. However, it is not showing the element and I cannot put a sprinkler head component or hanger component into the view. Is there a way to do this in Revit?
La'Veesha
3 ANTWORTEN 3
Nachricht 2 von 4
Alan.johnson1970
als Antwort auf: Anonymous
You could create them as 2D detail components and then place them in the section view
AJ.
Nachricht 3 von 4
Is it a drafting view or a section?  You can't put model components into a drafting view.  If you're trying to place sprinklers, do it in a ceiling plan - you should then see it in the section.
Nachricht 4 von 4
hmunsell
in a section or elevation you should be able to draw Detail lines or Place Detail components. as @Anonymous stated, if you want to place model families, you will need to make sure your section/elevation is not set to Detail. important note about that, any model family you place will be placed at the section cut line...
Howard Munsell
