Revit Door legend
4 ANTWORTEN 4
Nachricht 1 von 5
653 Aufrufe, 4 Antworten
Revit Door legend
Currently I am working on door schedules and trying to create the door legend. But I encountered below problem:
Particularly with the glass doors front elevation is not showing properly, (Not showing full length) basically no proportion at all. I tried changing the Host value but its changing the whole door value. Please find the below pic.
Any idea whats wrong?
Thanks in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
Avaris.
als Antwort auf: Anonymous
Is it a curtain wall door? In that case I would advice to make a cutout from the real door in your project.
Nachricht 3 von 5
I can readily see the reason from your screenshot why the door isn't reporting the Height and Width.  Those dimensions are not labeled (e.g. associated with Parameters).
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 4 von 5
Oops. Sorry @Anonymous ; I completely misread your screenshot. Disregard my previous post.
If that is a CW Door, we put those in a special CW “Legend” – which is actually an Elevation View in a Phase that pre-dates and is demo’d before all subsequent Existing and New Construction Phases.
Nachricht 5 von 5
You can create Assemblies from curtain wall doors, curtain wall windows, panels, and mullions. then create assembly views and use them for Legend.
