Revit Door Family - panel width
3 ANTWORTEN 3
Nachricht 1 von 4
iustinXVWHB
316 Aufrufe, 3 Antworten
I am trying to set the door lead to 920mm but cannot make it as wide as it needs to be.
Can you help?
Tags (3)
Beschriftungen (3)
3 ANTWORTEN 3
Nachricht 2 von 4
Yien_Chao
als Antwort auf: iustinXVWHB
check your door's type parameter.
Nachricht 3 von 4
iustinXVWHB
als Antwort auf: Yien_Chao
I tried. It is a nested family. For some reason it does not allow me to change the door leaf even though I updated it in the original family as you will see in the family attached.
Nachricht 4 von 4
Yien_Chao
i see.. you can try to map the nested parameter to another one in the family.
here an example of a window panel nested in a window family. The type family PanneauFenetre is selected and the nested parameter "largeur" is equal to LargeurPanneau1 (which is parameter the window's parameter, not the panel)
hope it's clear.
