I want to use the Revit family "Door-passage-single-flush" The default is set to masonry frame with a 1" offset. I have tried to edit the family to make the default a gyp wall not masonry and remove the offset but I cannot. This means I have to adjust every door or copy one I have changed. Does anyone know how to change the default to a gyp frame?
AAron
If you don't have any masonry conditions ever then you can do this:
But for the long run, I would change these parameters from Instance to Type so you can associate them to different Door Types.
Sounds like an Instance Parameter. Instead of changing the default, why not just Select All Instances in the Project and change the Parameter Value for all of them simultaneously.
...Select one Instance in the Project, Right-Click on it and press on Select All Instances: In Entire Project.
...otherwise change it to an Type Parameter if you can. You may not be able to if it is used in Formulas. Might be a chore.
