Revit doesn't work
8 ANTWORTEN 8
Nachricht 1 von 9
812 Aufrufe, 8 Antworten
Revit doesn't work
First at all my english is not the best. So this is the thing, i do the installation of the REVIT FREE TRIAL for student 2019 this version never open, the error said that i dind't have "mfc140u.dll" so i search it and installed the archive. Then this window(wich you can see in the jpg) started to appear, when you pressed "aceptar" revit closes and nothing more happend. Then i tried with de REVIT 2020, 2018 and 2017, i don't know what more can i do please help
8 ANTWORTEN 8
Nachricht 2 von 9
JacobDSimpson
als Antwort auf: Anonymous
Hi There,
Have you checked your computer settings to see if it is powerful enough to run Revit?
I would uninstall all of your Revit software, try to reinstall. If this doens't work I would contact AutoDesk support with the error code you are experiencing.
Try to follow the steps in this link:
https://blog.fix4dll.com/solved-mfc140u-dll-missing-error-revit-2017/
Nachricht 3 von 9
als Antwort auf: JacobDSimpson
i don't think that my computer was the problem, it is a Nootbook Acer E15 E5 575G. 8 gb ram, SD 256. GeForce 940mx, intel i 5-6200.
I just done the steps and nothing happend.. :enttäuschtes_Gesicht:
Nachricht 4 von 9
ennujozlagam
Hello, can try to go to desktop > select Revit icon > right click your mouse > select run as administrator and see if helps. And also here is the system requirements to run the Revit program, check your PC if meets the requirements. Thanks
Nachricht 5 von 9
Viveka_CD
Hi @Anonymous
Please downalod and install themfc140u.dll from  https://www.sts-tutorial.com/sites/downloadCenter.php?mfc140u
and then try to install Revit
Let me know how it goes.
Nachricht 6 von 9
als Antwort auf: Viveka_CD
ok, something change.. Now i am going to reinstall the program and then i' ll tell you
Nachricht 7 von 9
Viveka_CD
Hi @Anonymous
Yes, I'm looking forward to hearing from you!
Let me know how this goes.
Nachricht 8 von 9
Everything seems ok until i opened revit !
Nachricht 9 von 9
Viveka_CD
@Anonymous
Please try the steps below:
1.) Search the folder you installed the product from for a file called MSVCR100.DLL. If you find multiple copies select one with a file size of 809 KB
2.) Copy MSVCR100.DLL from the location in the install folder
Paste it into the following folders
C:\Windows\System32\
C:\windows\Syswow64
say yes to replacing the file
3.) Reboot your system and try launching the product again.
If that does not help, then try:
  1. Uninstall your Autodesk software from Control Panel > Programs > Programs and Features applet.
Note: If for some reason you are not able to uninstall your Autodesk software from Control Panel, please follow this link - Uninstall Using Microsoft Fix it
  1. Install Windows critical updates.
  2. Downloaded your Autodesk product installer using the Autodesk Virtual Agent (AVA), the Download Now method, or the Browser Download method.
  3. Follow General installation workflow for Autodesk Products to install your software.
Let me know if this helps resolve your issue.
