REVIT DOESN´T HAVE A PRINT TO PDF OPTION
Message 1 of 8
Hello I would like to export the sheet to pdf form. But for some reason revit doesn´t have the option. Yes, I have pdf installed I can export files to pdf. from AutoCad but seems like revit have no idea my pdf even exists. I tried to reinstall revit but it didnt help.pdf revit.png
  • PDF
Replies (7)
Message 2 of 8
"I have pdf installed I can export files to dwg. from AutoCad" - I meant to pdf. not dwg.
Message 3 of 8
ennujozlagam
try to install another printer driver like BULLZIP  (FOC) and see if helps. thanks
Message 4 of 8
Thank you, it does work. Any reasons why it cant find the regular pdf?
Message 5 of 8
ennujozlagam
you need to install those printer driver? thanks
Message 6 of 8
ennujozlagam
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Message 7 of 8
syman2000
You should check out diroot plugin for Revit. It allows you to batch export PDF, DWG & etc.
https://diroots.com/revit-plugins/revit-to-pdf-dwg-dgn-dwf-nwc-ifc-and-images-with-prosheets/
Message 8 of 8
elzohry2007
now in Revit 202 you can expport PDF
or
you can add any printer pdf Drive like PDf PRo or PDf xchange and print to pdf
