Revit doesn't export some properties to IFC
2 ANTWORTEN 2
Nachricht 1 von 3
cabriella_novello
320 Aufrufe, 2 Antworten
I had some navisworks WBS, search sets and a custom Pset, wich work together, before Revit 2023 april updates, but Revit soped exporting some properties to the IFC Pset, I've  noticed just for the revit Category
 the Pset
 an ifc exported before update
 the new ifc
Both exported with same sattings
Before updates, revit also exported to the element, his Type properties to a pset 'custom_pset (IFC Type)', and noticed that some default psets had some changes, like Revit PSets, and IFC Comon PSets
Tags (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Nachricht 3 von 3
ralphdenhaan
als Antwort auf: cabriella_novello
I had the same issue and fixed it by adding the normal entity and the type version.
so in your case: IfcWall, IfcWallType, IfcCurtainWall, IfcCurtainWallType.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
