Hi all,
We are having an issue with a model in Revit 2017. The problem is when we go and synchronize with the central model, then click the relinquish all mine, we get the warning saying "Revit cannot relinquish the changed elements because the project has not been saved. You must first synchronize your changes with the central model before you can relinquish changed elements, or close the file without saving."
Also, when we are done working on the file and sync, when closing the file we are asked if we want to sync with central.
It seems that when we sync, the elements are saved to the central so we are not losing any work but Revit does not seem to recognize that we just did sync the files.
Anyone else come across this problem before?
Howard
If you are confident that all your local changes are incorporated into the Central model, have you tried creating a fresh Local copy and see if this resolves it?
The first issue regarding Relinquish All Mine. That only works if you haven't made any changes to the project file. A change might seem inconsequential to the user but to a computer (Revit) it is still regarded as a change. You can close a file without saving/syncing and Revit will ask if you want to relinquish elements or retain them. If the user really didn't make any changes then closing the file and choosing the top option presented to relinquish elements is appropriate.
When a change is made Revit expects us to synchronize that change. I recommend people ONLY use the Synchronize and Modify Settings option. It presents us with a dialog and we can confirm that all relevant check boxes are checked. When we use the Synchronize Now option that does NOT present us with a dialog AND it does NOT relinquish User-Created worksets. Only Synchronize and Modify Settings allows us to do that.
Generally, when we close a file and a prompt warns us to synchronize then something has changed in the file since the previous successful sync was done, regardless how recently that happened. It should only do that because it is necessary. Don't disregard it. For example, during the course of syncing Revit may have added something to your Local File that changes it beyond your own changes.
If you do end up in a loop of Sync > must Sync > Sync > must sync... then another way to approach the matter is to chose File (Application menu) > Close. You'll get a prompt to sync and doing so will be followed by Revit closing the project. If you can't close the project you've got something the Autodesk Support staff really needs to see.
There seems to be a slight recurring theme lately about Revit prompting users to sync after syncing already but I haven't seen any evidence that suggests it is a bug or Revit issue yet. There are a lot of variables so I think more evidence and clues are necessary to come to that conclusion from where I sit.
Steve Stafford
You might want to check your latest local to see how complete it is - and then create a new central model.
Hi @hebloom
I just wanted to follow up here, any progress on this issue? Did the recommendations by the experts help resolve your issue?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi Viveka,
I have not had a chance to try the solutions. I hope to have some time soon to try them.
No worries @hebloom
If the issue persists, please send us your journal file to troubleshoot further. I can forward you a private upload link if you do not want to post here.
Looking forward to hearing from you.
Viveka CD
I have the very same problem with Revit 2017. How can I privately send you my journal file for diagnosis?
Hi @Anonymous
I have shared a private upload link to your email.Let me know if you have trouble accessing the files.
Viveka CD
Hi @Anonymous
I didn't receive the file, can you please resend?
Viveka CD
@Viveka_CD Did you receive my journal file? Any ideas what is wrong? Thank you.
Hi @Anonymous
I have not received files from you.
I've shared another private folder with you. Let me know if you can access this folder.
Viveka CD
@Anonymous Thanks for letting me know!
Viveka CD
Hi @Anonymous
Can you confirm if you have the updates installed for your Revit version?
Is this user specific? Send us that model as well and we can test if for corrupt elements.
Viveka CD
@Anonymous thanks for the update. We will troubleshoot and let you know for any updates.
Viveka CD
