Revit display problem
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
mnguyen2AASC
462 Aufrufe, 6 Antworten
Good morning,
I need your support for my project. Me and my colleague are working on the same project. Normally if someone opened the project, the other could not see it (we only see the project backups). But with this project, we see it again. So it happened twice times that we worked on the same project at the same time. And today, there is a display problem when I open the project, we see that the exterior walls are transparent but they are correct when we print it. I will send you the photo in attachment. Has anyone had this problem? how can I fix it please? Thank you so much!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: mnguyen2AASC
Those lines aren't transparent. They look like Hidden Lines from here. Go to View Tab and click on Remove Hidden Lines. They could also be Linework, in which case you would need to the Line Style to "BY CATEGORY" (Modify Tab=>Linework). They could also be applied by through the View's Category or Element Graphic Overrides.  I can think of other ways as well.
Post your RVT here so I don't have to guess anymore.
Nachricht 3 von 7
...wait a minute. Are you wanting to hide them in the Views?  Select one, right -click and press Hide In View By Element or By Category.
Nachricht 4 von 7
mnguyen2AASC
als Antwort auf: barthbradley
Hi Brarth,
Thanks for your answer! No, I don't want to hide them. Before yesterday, my elevation display correctly like the good photo in attachment. But today when I re-open it, my elevation display like the other photo. I checked graphic display option, it is always on mode hidden line. When I moved the computer mouse near the element, Revit selected the wall exterior which is transparence (see attachment).
Thanks!
Nachricht 5 von 7
mnguyen2AASC
I send you my RVT. Only my right elevation display correctly.
Thanks a lot!
Nachricht 6 von 7
Ah! I see now! I completely misunderstood you. Sorry.
Turn off Imported Categories.
Nachricht 7 von 7
mnguyen2AASC
Oh dear, thank you so much! I don't have any idea why it turn on automatic like that. Thanks a lot for your help! Have a good day!
