Revit Devide path
Revit Devide path
Eduard_KmetVJTPS
Revit Devide path
Eduard_KmetVJTPS
Hi everyone, I have this problem in Revit - I have lines loaded in a generic model that I divide using divide path - on the created points I then load an adaptive profile through 2 points. And when I load 2 profiles, I use Repeat so it creates them everywhere. The profiles (or rather those lines) behave strangely, because some are placed on one side and others on the other side. Could someone explain to me why this happens and if I can somehow eliminate this problem? I'm also attaching the Revit family, where both the host and nested family are included. Thanks in advance.
RDAOU
@Eduard_KmetVJTPS
I do not have access to Revit at the moment to check the family you posted but in general 2 points adaptive is not always suitable for all applications. It relies greatly on how you have set up the adaptive placement points and polarity of the divided curves . Hence in some instance the elements will flip unpredictably. Using more placement/adaptive points (3, 4 and sometimes more) makes the repeaters more accurate.
