Revit Default Server Problem
saniul_hoda
saniul_hoda
Michael_Brownnutt
Observer
Observer
Thanks - but what is this?
saniul_hoda
This is an error/warning message that I am getting while opening the Revit.
handjonathan
Hi @saniul_hoda
Thanks a lot for posting your question to the forums!   Can you try the below.
Revit 2022 and later versions
As Repair/Reinstall is not available, uninstall Revit, then reinstall.
Revit 2021 and earlier versions
  1. Program Repair: Windows Start > Control Panel > Programs > Programs and Features > Uninstall a Program > “Uninstall/Change" > “Repair or Reinstall” > Repair.
  2. If that doesn't resolve the issue, continue with a Program Reinstall as follows: Program Reinstall: Windows Start > Control Panel > Programs > Programs and Features > Uninstall a Program > “Uninstall/Change" > “Repair or Reinstall” > Reinstall.
  3. If the behavior continues after repair/reinstall, try switching to roaming user profiles.
Note: If the reinstallation does not help, check if Mandatory User Profiles are used and if so use Reaming Profiles instead.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
saniul_hoda
Thanks a lot. I will try with your suggestions.
