any help in installing DB Link ????????????????????
https://apps.autodesk.com/RVT/en/Detail/Index?id=5072854987084642377&appLang=en&os=Win64
@Anonymous, you'll need an active subscription to be able to download this addin. All the downloads for the latest Revit versions have been moved to the Autodesk account: https://manage.autodesk.com/
For Revit 2018 you need the DB link for Revit 2018. This can be found in your account or in the Autodesk Desktop App
Louis
Please mention Revit version, especially when uploading Revit files.
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new visitor.![]()
Did the recommendation by @L.Maas help?
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
