I have created a custom pattern based on a grid coordinate that I created in AutoCAD (attached). When I import it into Revit, it seems to stack in a funky way (also attached) and I am not sure what I am doing wrong. I was following the logic of the formula, but there might be another way to do it? I have a repeating pattern but the unit of custom values are not adjacent to each other like most simple patterns.
The Pattern:
*Nichiha Fiber Cement, Offset Random
;%TYPE=MODEL
0, 0, 0, 0, 18
90, 0, 0, 90, 300, 18, -72
90, 0, 60, 90, 300, 18, -72
90, 0, 96, 90, 300, 18, -72
90, 0, 144, 90, 300, 18, -72
90, 0, 228, 90, 300, 18, -72
90, 0, 276, 90, 300, 18, -72
90, 18, 18, 90, 300, 18, -72
90, 18, 102, 90, 300, 18, -72
90, 18, 126, 90, 300, 18, -72
90, 18, 174, 90, 300, 18, -72
90, 18, 234, 90, 300, 18, -72
90, 18, 258, 90, 300, 18, -72
90, 36, 6, 90, 300, 18, -72
90, 36, 54, 90, 300, 18, -72
90, 36, 78, 90, 300, 18, -72
90, 36, 162, 90, 300, 18, -72
90, 36, 198, 90, 300, 18, -72
90, 36, 222, 90, 300, 18, -72
90, 36, 270, 90, 300, 18, -72
90, 54, 0, 90, 300, 18, -72
90, 54, 84, 90, 300, 18, -72
90, 54, 132, 90, 300, 18, -72
90, 54, 216, 90, 300, 18, -72
90, 54, 240, 90, 300, 18, -72
90, 72, 30, 90, 300, 18, -72
90, 72, 54, 90, 300, 18, -72
90, 72, 114, 90, 300, 18, -72
90, 72, 138, 90, 300, 18, -72
90, 72, 162, 90, 300, 18, -72
90, 72, 210, 90, 300, 18, -72
90, 72, 270, 90, 300, 18, -72The coordinate system and pattern used to creat .pat
The end result in Revit (the gray portion)
You might try "reverse engineering it"--import the cad drawing into a drafting view.
Then use a "hatch pattern maker" like Hatch 22 , or PyRevit to create the pattern.
You have mixed-up the origin for every line. The 2nd and 3rd entry on a line is the X [2nd entry] -Y [3rd entry] coordinate of the origin of the line. Swap those and it will be fine.
