Revit Custom Families - Exporting materials
1 ANTWORT 1
Nachricht 1 von 2
413 Aufrufe, 1 Antwort
Hello everybody,
I am trying to export my model to Lumion for rendering. It contains some custom made families that I modelled in AutoCAD and than imported to a family, which was then imported to the project.
Then i assigned all the materials to each layer of the original file via the Manage Object Styles. But when exporting to lumion (Collada and other extensions) all these custom-made families are recognized as DEFAULT MATERIAL even though i assigned them different revit materials that are clearly visible in revit.
Do you kniw how can I export correctly giving various materials to all the different parts (layers) of a single family?
Thank you!
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Make sure all the colors in the CAD file are "bylayer", not overridden (forced) in Autocad, otherwise this above will not work.
