Revit Curved Windows
tedkavanagh
tedkavanagh
I want to make a window family with highish curved heads. When I us the standard window template by default it appears to only allow me to make a window with a straight head (top). Am I missing a trick?
Many thanks,
Ted.
constantin.stroescu
If you want to make a Window Family with an arc top :
  • open Window Template Family - in Exterior ( or Interior) View select ( using TAB) the Opening Cut
  • use Edit Sketch to change the upper part into an arc
  • use family parameters to control the height of the arc
Constantin Stroescu
constantin.stroescu
 I attach a screecast to show how the parameters work..
Constantin Stroescu
