revit curtain wall mullion make continuous
hello
I'm working on a curtain wall project in Revit. Currently, my vertical mullions are being split by transoms, which makes it difficult to extract accurate material takeoffs.
Is there a way to prevent mullions from breaking at every grid intersection? Using parameters to group them takes too much time for large-scale projects
I need to merge these split mullions into a single continuous member and place joints at specific locations (ex_a 10mm gap) rather than at the center of the transom.
The reason I need a joint gap is to ensure that the actual construction details are accurately reflected in the shop drawings. In Revit, I need to represent a 10mm gap between mullions rather than having them joined at the center of the transom. This is essential for both precise material takeoffs and generating shop-level detailing.
thank u
