Revit crush on sturtup 2017 w7x64
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
ZorgIT
440 Aufrufe, 1 Antwort
I have a subscription license, and i know what all Autodesk product have many many many bug if it's released, i wait for sp2 for revit, and now i try to use it:
1. i delete ABDSP 2016 and instal 2017 without any problem.
2. I can run Autocad, 3d's max but Revit cant's start
in enent viewer:
Имя сбойного приложения: Revit.exe, версия: 17.0.416.0, отметка времени: 0x56cf8ad9
Имя сбойного модуля: RevitDB.dll, версия: 17.0.416.0, отметка времени 0x56cf88ef
Код исключения: 0xc0000005
Смещение ошибки: 0x000000000050525b
Идентификатор сбойного процесса: 0x2504
Время запуска сбойного приложения: 0x01d24e7a2f404767
Путь сбойного приложения: C:\Program Files\Autodesk\Revit 2017\Revit.exe
Путь сбойного модуля: C:\Program Files\Autodesk\Revit 2017\RevitDB.dll
Код отчета: 7292200a-ba6d-11e6-99f8-c86000cc9cbb
About configuration:
W7 x64 (all update installed)
.Net Framework 4.6.1
VCRedist 2005,2008,2010,2012,2013,2015 all x86\x64
i7 4930
Nvidia quadro k2000D
16Gb RAM
What i try:
1. Reinstall Revit 2017
2. Reinstall Net framework
3. Reinstall all VCredist
4. Disable Antivirus (Nod32)
5. Disable UAC
6. Delete this folder
C:\Users\<username>\AppData\Local\Autodesk\Revit\Autodesk Revit 2017
C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2017
Delete this registry
HKEY_CURRENT_USER\SOFTWARE\Autodesk\Revit\Autodesk Revit 2017
7. Install all update avilable now sp1 sp2 2017.1
What kinde of information you need to help me solve the problem.
1 ANTWORT 1
Nachricht 2 von 2
ZorgIT
als Antwort auf: ZorgIT
Solwed for me with Autodesk support:
  • Open Windows Registry by clicking on Start button > type regedit > hit ENTER
  • Navigate to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
  • Find the key Common AppData
  • Double-click it and check if the value is set to C:\ProgramData
    • If it is different, please tell us which value you see. Then change it with the value above and then restart Revit "
In my situation this key is empty, i add C:\ProgramData to it and it's start and work.
