When I set (accidentally) a negative value to a Length parameter, Revit crashes. The following message is shown:
"A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects.
Would you like to save a recovery file?"
And then Revit closes.
The journal file last lines, starting in the moment that the parameter value is changed, are shown bellow.
Does anybody know why this happens and how to avoid the crash?
'<<End update Provider-triggered panels>>
'E 10-Dec-2019 08:13:56.766; 0:<
Jrn.MouseMove 0 , 16 , 201
Jrn.PropertiesPalette "Activate"
'E 10-Dec-2019 08:13:56.772; 0:<
Jrn.Grid "Control; FormView , Properties , IDD_PROPERTIES_PALETTE; IDC_SYMBOL_GRID" _
, "Selection" , ""
'E 10-Dec-2019 08:13:58.133; 0:<
, "PartialEdit" , " Comprimento" , "ValueCol" , "-3" , "2" , "2"
, "MoveCurrentCell" , " Comprimento" , "ValueCol"
' 0:< Unnecessary nesting;ElemGrid_1;-1;IDS_MODIFY_TYPE_ATTRIB ;N++EB(NB);
' 7:< Error posted:
' 7:< Parameter Comprimento has an invalid value.
' 4:< Error posted:
' 4:< An error occurred in family "PERFILADO" that cannot be automatically resolved.
'Error Information:
'"Parameter Comprimento has an invalid value."
'C 10-Dec-2019 08:13:58.163; 4:< Invalid Parameter!!! <Need debug version of CRT library for more information> Go to crash protection.
' 4:< BC: 1,4638,1
' 4:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 4:< RAM Statistics: 10485 / 16361 769=InUse 4280=Peak
' 4:< VM Statistics: 134208366 / 134217727 2895=InUse 4044=Peak
' 5:< ::454:: Delta VM: Avail +21 -> 134208381 MB, Used -25 -> 2875 MB; RAM: Avail +225 -> 10711 MB, Used -12 -> 760 MB
' 5:< GUI Resource Usage GDI: Avail 8962, Used 1038, User: Used 623
' 5:< Revit worker 1 closed cleanly
' 0:< [00001f64]QueueMinder stopped
'C 10-Dec-2019 08:13:59.356; 5:< logging finished virtualization services
'C 10-Dec-2019 08:13:59.356; 5:< logging finished worker services
'C 10-Dec-2019 08:13:59.369; 5:< logging erased queues
' 1.201117 5:<<<Terminating Slave Processes
' 4:< ::454:: Delta VM: Avail +67 -> 134208449 MB, Used -89 -> 2787 MB; RAM: Avail +174 -> 10886 MB, Used -24 -> 737 MB
' 4:< GUI Resource Usage GDI: Avail 8957, Used 1043, User: Used 601
' 4:< CefSharp has been shutdown successfully!
' 4:< Unconverted MessageBox "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects.
'Would you like to save a recovery file?"
' 4:< ::454:: Delta VM: Avail -22 -> 134208428 MB, Used 2787 MB; RAM: Avail 10886 MB, Used 737 MB
' 4:< GUI Resource Usage GDI: Avail 8953, Used 1047, User: Used 608
' 4:< Family Dialog Bar : WM_WINDOWPOSCHANGING: cx-0, cy-0, x-0, y-0
'E 10-Dec-2019 08:13:59.849; 4:<
Jrn.PushButton "FormView , Properties , IDD_PROPERTIES_PALETTE" _
, "Apply, IDC_APPLY"
' 4:< Unnecessary nesting;d:\ship\2019_px64\source\revit\desktopmfc\ui\PropertiesPaletteView.cpp;1084;IDS_MODIFY_ELEM_ATTRIB ;N++EB(NB);
' 4:< Appendable opton;-;d:\ship\2019_px64\source\revit\desktopmfc\ui\PropertiesPaletteView.cpp;1253;IDS_MODIFY_TYPE_ATTRIB ;N--OB(NAB);
' 4:< Unnecessary nesting;d:\ship\2019_px64\source\revit\desktopmfc\ui\PropertiesPaletteView.cpp;1906;IDS_MODIFY_ELEM_ATTRIB ;N++EB(NB);
'H 10-Dec-2019 08:13:59.853; 4:<
Jrn.Data "Restricted Propagation" _
, 2, 11
' 4:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewProject id=3651: 966 elements need cache update
'E 10-Dec-2019 08:14:07.977; 4:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(YesNo,Revit).Click(No)"
'H 10-Dec-2019 08:14:07.983; 4:<
Jrn.Data "MessageBox" _
, "IDNO", "A fatal error has occurred. The application will be terminated. You have the opportunity to save recovery files for all of your changed projects. " & vbLf & "" & vbLf & "Would you like to save a recovery file?"
'E 10-Dec-2019 08:14:07.983; 4:<
' [Jrn.AutoConvertedMessageBox] Rvt.Attr.MessageId: IDS_UNRECOVERABLE_ERROR Rvt.Attr.MessageAnswer: IDNO
' 4:< DBG_INFO: Recent Dynamic Added but not to Dynamics, this means that this element is not dynamic anymore with RDYs removed.: line 185 of d:\ship\2019_px64\source\revit\revitdb\display\GraphicsMgr.cpp.
'C 10-Dec-2019 08:14:07.990; 4:< program terminated
Does the family do the same thing in other projects (such as new blank project?
You can fix the family by including a parameter that disallows a negative value for length.
Yes, it has the same behaviour in any project.
I was hoping that there was an explanation for the crash because it seems really problematic that Revit closes because of a typo.
