Hi All,
I'm getting a Revit crash when I try to move and snap my properties and project browser tabs back to the main revit window. Do any of you all know why this is happening?
I've adjusted my display scale, signed in, signed out, turned off the tabs, turned them back on and everything.
It will crash once the blue highlighted rectangle flashes up where the tab is supposed to fit. No errors, the blue ring spins for a second, then takes me to the autodesk error submission page.
Any advice?
Cheers,
Dan
Gelöst! Gehe zur Lösung
Gelöst von monch160. Gehe zur Lösung
Resolved, and leaving this up here incase other people need the help.
see image:
in an effort to try and adjust DPI on an external monitor, I went and changed the high DPI settings, not only did it not help my external screen blurriness, it also made revit crash during the window/tabs issues that I mentioned above.
I checked those boxes circled in red which caused the issues. Leave them unchecked.
Answer: don't adjust these settings. Keep them set to the default.
