Dear Richard,
Thank you for contacting Autodesk Technical Support.
My name is Riccardo. I am a Revit specialist, and I will be helping you with your Service Request.
In order to better investigate you issue I would appreciate if you could add the the Project File and a Journal file.
If I do not hear from you within 2 business days, I will archive the case. Despite of it, if you have any additional questions or concerns you can still post them here.
I am looking forward to hearing from you.
Best Regards
Riccardo Evangelista
Autodesk Support Team
Hi
The same happens to me now… Have tried to delete all the plugins but Revit v.2016 still crashes when closing a project file.
I tried the Windows 10 Repair option and then reinstall but Revit still crashed. Did then a clean Uninstall (https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...) and after installing Revit again the problem is no more… Boring job but it fixed the problem.
