Revit crashes
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
1457 Aufrufe, 7 Antworten
Revit crashes
Hello! I need your help, please
Revit 2016 crashes when I work with the file with linked models. When links are not loaded everything is fine. But when they loaded, file crashes, while I’m opening any view or even when I load link. It happens only with one model and only on one computer. All the latest updates for Revit and video card are installed. What could be a possible reason for that?
The journal is attached
Tags (1)
7 ANTWORTEN 7
Nachricht 2 von 8
FGPerraudin
als Antwort auf: Anonymous
Hi @Anonymous,
I might be wrong but I have the impression that Revit is running out of virtual memory.
Have you got more that 2GO of free space on your main Hard drive (the system one) / and/or memory management drive?
François
Francois-Gabriel Perraudin
BIM management and coaching
Nachricht 3 von 8
L.Maas
From my interpretation of the journal file i see few things.
-Revit can not find all linked file
-Not all the files are from the same Revit version
You could try the following.
-Make sure the linked files can be found.
-Try to load the links one by one and see if it is a specific linked file that causes the problems
-Load the linked files standalone and see if there are issues with one or more of the files
-Upgrade the linked files before linking them in the host project.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 8
als Antwort auf: FGPerraudin
Hi François
thank you for your respond
don't think this is the problem((  I have enough free space and virtual memory
Nachricht 5 von 8
als Antwort auf: L.Maas
Hello Louis
Thank you for recommendations
-Make sure the linked files can be found.  - have done it. If all the files are loaded Revit crashes while opening some of the views
-Try to load the links one by one and see if it is a specific linked file that causes the problems- have done it. Opened all the linked file with AUDIT option and resaved it, didn't help
Nachricht 6 von 8
L.Maas
If you know a particular view that crashes Revit, I would try the following. With visibility/graphics overrides hide all linked files in that view. Close and open the view and see if it does not crash. If it does not crash unhide a link and repeat the process (close and open the view). Repeat until it crashes again. If you can fix it down to a single linked file you could repeat the process and hide/unhide different categories to see if the issue can be attributed to a single category/family which you might be able to correct
Louis
Nachricht 7 von 8
Nachricht 8 von 8
Thanks for the update.
Please mark it as the solution so others can find it if the same error
happens to them.
