Revit crashes when I set a work plane.
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
jorgedelacova7458
635 Aufrufe, 8 Antworten
One of our staff is repeatedly getting a Revit crash when trying to set a work plane. Has anyone encountered this issue before?
8 ANTWORTEN 8
Nachricht 2 von 9
JuanYusta
als Antwort auf: jorgedelacova7458
Nachricht 3 von 9
jorgedelacova7458
als Antwort auf: JuanYusta
I reviewed the links you sent (and thank you!). None of them covered the problem of a crash when setting a work plane.
When Revit crashes, it gives the "unrecoverable error" message.
Nachricht 4 von 9
ennujozlagam
try to tick audit before opening the file, clear as much possible of warnings and install latest updates from autodesk and see if helps. thanks
Nachricht 5 von 9
jorgedelacova7458
als Antwort auf: ennujozlagam
This is happening on all projects, including the Revit sample file.
Nachricht 6 von 9
We have even reached out to Autodesk customer service. They said to make sure all the Revit 2019 updates are installed (they are) and to see if disbling add-ins solves the issue (it doesn't).
Nachricht 7 von 9
Matt.Wunch
@jorgedelacova7458 is this happening for ALL users or just isolated to a single machine?
Maybe try disabling hardware acceleration? Make sure any available graphics card drivers are installed.
Nachricht 8 von 9
noc
Observer
Hi
This also happens to me. Revit 2021.1.1.2. As soon I set the workplane to a named ref plane, it just shuts down without any warning
Nachricht 9 von 9
We had to take the blunt approach and reimage the machine. No problems after that.
