Revit Crashes when i open a new template or existing file
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
londonZ7F92
553 Aufrufe, 2 Antworten
Revit 2023 Crashes when I open a new template or some existing files... for example the sample file opens fine.
I've done an clean uninstall, but the problem is not solved.
Apparently also a previous version 2021 that I have is with the same problem. Screenshots are attached
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: londonZ7F92
Follow these steps to resolve the issue:
  1. Close all Revit Sessions on the affected machine.
  2. Rename the following file (instead of removing the folders listed in the solution below): C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\Autodesk Revit %VERSION%\DDGraph
  3. Restart Revit.
Alternatively:
Copy and paste a healthy DDGraph file from another machine, where the issue is not reproducible.
If the above steps do not help, clear the content of the following folders:
  • C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Autodesk Revit %VERSION%
  • C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\Autodesk Revit %VERSION%
%USERNAME% should be your windows login name.
%VERSION% should be your Revit version.
Nachricht 3 von 3
londonZ7F92
als Antwort auf: ToanDN
Unfortunately it doesn't work.
I found the problem. It is because of the latest updates from Speckle. I
downgraded Speckle to 2.7.2 and the problem disappeared
thanks
