Revit crashes on moving Spot Elevation
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
michael.kerscher
575 Aufrufe, 3 Antworten
I have a problem with foundation and the spot elevation on it.
Everytime the foundation would be moved or rotated revit throws a message that a "serious error has occurred".
If the spot elevation is moved or anything else done with it, then Revit crashes completely. I reported this error to Autodesk with the error report number CER_206567706.
If I delete the spot elevation and create a new one of the same type everything works fine, but I want to know where this error comes from.
The project and the journal log can be dowonloaded by anyone who wants to test the error:
Error Report on OneDrive
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: michael.kerscher
i don't find any issues, try to tick audit before opening the files and untick use hardware acceleration from options and see if helps. thanks
Nachricht 3 von 4
michael.kerscher
als Antwort auf: ennujozlagam
Audit and disable hardware accelaration do not bring the desired success.
But in the new Update 2020.1 Revit doesn't crash anymore.
Nachricht 4 von 4
ennujozlagam
ok that's good. yes installing updates fixed some issues. thanks
