revit crashes converts from 2021 to 2009
5 ANTWORTEN 5
Nachricht 1 von 6
leonard.means.1
370 Aufrufe, 5 Antworten
I have had revit crash and it required me to force stop the program.  I was trying to save at the time.  When I try to reopen the revit it ask if I want to upgrade from 2009 to 2021.  The whole project was done in 2021.  There are some families I upgraded but none of them were from 2009.  This has happened twice now.  I was working remote VPN and the server has the shared license. I can open up a previous saved version and it does not require the upgrade.  Since this has happened I have saved frequently but would like to know how to prevent this.  Thanks
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: leonard.means.1
It is a false warning.  Update your revit 2021 to the latest Build.
Nachricht 3 von 6
leonard.means.1
I have tried that and it does not update. When I select the upgrade I get a failure to open project notification.
Nachricht 4 von 6
What is your Revit 2021 Build Number?  Get it from this button then About...
Nachricht 5 von 6
No luck here either.
You might want to submit to Autodesk by opening a Support Case through your Account Portal.
Nachricht 6 von 6
leonard.means.1
als Antwort auf: ToanDN
21.1.21.45
20201116_1100(x64)
