revit crashes after windows update, both 2014 LT and 2015
Both program crash and will not open following a windows update
ennujozlagam
hi, then uninstall the updates if crashes your proram, check updates could be in sequence. thanks
Ihad the same issue with Revit 2013lt. It had something to do with .NET framework update to 4.6.1. I did unisntall it and reinstall .NET framework 4.5.2. Revit has been working as usual since then.
