Can anyone explain this or someone from Autodesk?
Gelöst! Gehe zur Lösung
Gelöst von azad.Nanva. Gehe zur Lösung
Try exporting the view without being in that specific view; it might be a graphics card issue
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Hi @azad.Nanva,
Is your software upto date?
have you come across the below link?
Crash-at-trying-to-export-a-Revit-file-to-DWG
Thanks.
thanks to your answer and with thanks to Autodesk group, I found the problem,it is still takes too much time,but not crashing.so it solved with download the last version of :
“RealDWG 2025.1.1 64-Bit Update”
