Hi.
I have been using the BIM Interoperability Tool in Revit 2018 for quite some time now. However, I recently had problem in using the Classification Manager Tool. I could not Setup or Assign any element. I have tried to restart Revit, and it only worked fine for a few minutes. Any idea why? Could it be possible that some data in my Revit model is corrupt in some way?
You probably need to do some troubleshooting.
-Try on a different and/or new project and see if it works.
-Try to reinstall this add-in.
-Try to remove other (possible conflicting) add-ins.
-If it works at some point try it on a copy of your project and start removing elements fromn your project and check if it starts to work a certain time.
Louis
Please mention Revit version, especially when uploading Revit files.
We are also experiencing this problem. Quite frustrating as it just churns out a message only a robot will understand.
