- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi. Revit constantly forces wrong alignment on walls when a slope is added to one of the walls profile.
I've attached an image.
#1) 3 walls are conencted, all good.
#2) 3D view of the 3 walls, all good.
#3) Added slope to one wall's profile, all good still.
#4) Raising the height of another wall to match the height of the sloped wall, and revit screws it up and changes the alignment.
The way it looks in #4 is not how it's contructed in real life so i need revit to stop this weird behavior. It should look like in #3 but with the thin vertical wall matching the height of the thick wall with sloped profile.
I have tried various ways and orders of constraining the walls but nothing seems to help it actually changes the alignment or dimension (if i use that instead of constraints) even though they are locked, but no error/conflict msg is displayed.
I can't use anything but "normal" walls cause it's to be used in another program and that program can't calculate wall and glass areas if things like masses, void extrudes and curtain walls are used. So only standard walls, windows and doors.
kind regards
a frustrated revit user
