Hi there,
Does anyone know if there is a set amount of times you are able to render to the cloud in the educational version of Revit? I am using the 2016 student version.
When does it reset?
Josephine
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
You can render 25 times (images).
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution
@JAFarnsworth hello, if you are studesnt autodesk will give you unlimited cloud rendering credits check <<click HERE>> or <<click HERE>> . thanks
