I have been doing cloud renders for a while now with multiple design options.
For the first time i am having issues with revit 2019 whereby i have duplicated one view and added different design option for this. The right handside wall view in the main model only the left hand side front of wall is in design options. All lightings are in main model. Take a look at the image attached, one view has right hand side brighter than the other where as for both views right hand side should remain same.
Can someone please advise.
I even changed the original views design options just to ensure no issues with duplicated view, still same result.
fyi: I have marked the right hand side with red circle
The Brightness is because of the Lighting fixture or the glowing material?
I feel you need to fix the material..
Thanks, but material is same in both options, left hand side is the only part in design option, right hand side shouldnt be affected, material and lights are all same. I dont understand why right hand side wall in one option it appears brighter than the other
