Revit Chimes when Deleting Elements
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
3847 Aufrufe, 16 Antworten
Hi!
I am working in my Revit project file and am constantly deleting and replacing furniture items and walls. Every time I delete an element, there is a loud chime that goes off. It is the same chime that goes off when a warning box pops up, but I was able to turn those off. The only way I can turn off the "deleting elements chime" is by muting my entire computer, but sometimes I share my screen on Zoom and need to hear people on the call. Does anyone know how to turn off the sound that occurs when deleting elements?
Thanks in advance!
Beschriftungen (2)
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: Anonymous
Why is it chiming?  What's the error?
Nachricht 3 von 17
als Antwort auf: barthbradley
Hi barthbradley,
It is chiming every time I delete an item. No error or warning message appears. If I place a couch, wall, or any other item but decide to delete it, it chimes. It is so strange!
Nachricht 4 von 17
Well, there's a warning or error associated with the chime.  You don't see anything?  Did you have a dual monitor setup at one time?
If you did, the warning/error dialog box may be off screen.
Nachricht 5 von 17
Nachricht 6 von 17
Good to know. I have never had a dual monitor set up with this laptop, so I don't know where the error/warning box has disappeared to... do you know how to get it back? I just did some research and it tells me to go to Manage -> Inquiry -> Review Warnings but the Review Warnings button is greyed out. I appreciate all of your help.
Nachricht 7 von 17
als Antwort auf: ToanDN
Thanks, ToadDN! Hopefully once I get my error/warning box to appear again, I can use this to turn off the chime.
Nachricht 8 von 17
That's a good thing.  No Warnings. Pat yourself on the back.
Now, where the heck is the warning box that's associated with the chime? Got me.
Nachricht 9 von 17
Now I'm manually causing an error (drawing a wall on top of an existing wall) and the error box appears, but NO CHIME! There is still a chime with every item I delete. I'm at a total loss :enttäuschtes_Gesicht:
Nachricht 10 von 17
Also, I'm using Revit 2019 - Student Version. Not sure if that'll change anything for anyone helping me troubleshoot.
Nachricht 11 von 17
You sure it isn't your phone?
Kidding.
Very weird.
Nachricht 12 von 17
martijn_pater
Turn off your sound...
Nachricht 13 von 17
RobDraw
Are you using the keyboard delete key or the Revit command? Does it still make a sound if you delete in an alternative method?
What kind of error could be happening? (Delete by itself does not make a sound.) Are these elements pinned?
Have you ever had a second monitor plugged in? If so, try connecting another one so you can see that error message.
Rob
Nachricht 14 von 17
Turn off Windows system's "Exclamation" sound then.
Nachricht 15 von 17
….or change your wav from Chimes to Electric Love. he, he.
Nachricht 16 von 17
als Antwort auf: RobDraw
You're onto something here... I used the delete button in Revit and there was no chime. The chime only occurs when I delete something using my keyboard. I have turned off the sound from my computer settings and it fixed the issue. Thank you for your help!
Nachricht 17 von 17
RobDraw
So, your keyboard has a feature to make a sound when the delete key is pressed. Check your keyboard settings.
Rob
