Revit Central file / worksharing issue
3 ANTWORTEN 3
Nachricht 1 von 4
329 Aufrufe, 3 Antworten
Our problem is the central file gets created - one user can create a local file from it, while another cannot because the 'create new local' is greyed out. Worksharing is enabled in the file. The central file location is located on the main office server. HELP!
This is the first time we have used Revit 2017 with TWO folks in the file. This is a learning curve issue likely easily solved.
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: Anonymous
Hello, you can refer below. Thanks
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 3 von 4
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new member.
Did the resolution at the article link provided by @ennujozlagam help resolve your issue?
Also see the article HERE for further recommendations.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Nachricht 4 von 4
paullimapa
This actually happened to us when we were running Revit 2015.
The problem we discovered was caused by the volume of where the Revit central file was stored was mapped differently on various staff computers.
Once we made sure everyone's computer is mapped the same way, then the 'create new local' was no longer greyed out.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
