Revit cannot run the external application 'P&ID Modeler'. User getting this error kindly help.
Hi @Anonymous,
I understand that reinstalling Revit and the addins did not help.
I suspect, that the P&ID Modeler is using a *.dll file, with a name which is already being used by another addins *.dll filename. This way Revit loads the other addin first and fails to load P&ID modeler.
Please, try this workaround and let me know if that works:
Also: The details in the error message might give a hint about the affected dll files and addins - please, add screenshots with the details to this thread as well.
We look forward to hearing from you.
Hi @Anonymous,
Just a quick follow up.
Did you find my suggestions helpful? Have those allowed you to resolve the issue with P&ID Modeler?
Don´t forget to give us a feedback - we look forward to hearing from you.
Best regards,
Hi @Anonymous,
I was sorry to hear that my suggestion didn´t work.
So I understand, that deactivating all other addins on the affected machine doesn´t change the behavior and the P&ID Modeler throws an error regardlessly.
In order to help you better I will need diagnostic data to look into.
I look forward to hearing from you.
Best regards,
