Revit cannot detect correct paper size when print PDF
2 ANTWORTEN 2
Nachricht 1 von 3
974 Aufrufe, 2 Antworten
Hi everyone,
I'm with PDF Printing and I have a problem:
When I create a custom PaperSize in control panel (Ex: 1000x500). The DefautPaperSize is automatically changed to new one.
When I came back to Revit and print a normal PaperSize (A2.) Revit cannot detect the correct papersize even if I modified correctly in print setup.
How can I fix it?
Thank you.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
So you are modifying the paper size for CUSTPDF....but in Revit you are selecting Adobe PDF....shouldn't you be selecting CUSTPDF in Revit?
Nachricht 3 von 3
I just create custom papersize for some specific sheets. But when i print standard sheet (ex: A0, A1, A2), Revit just detect only custom papersize I created.
