REVIT - Cannot Creat New Local
1 ANTWORT 1
Nachricht 1 von 2
221 Aufrufe, 1 Antwort
I am working in Revit 2016 and attempting to open a local file to work in as our design team does normally. However, when I go to open our model, I get error message: "Revit could not create a local file from the file location. This could be due to a network problem. You can try again or contact technical support." Other users on our team are able to access the project and write new locals on their machines with no issue. Any ideas as to why this may be happening?
1 ANTWORT 1
Nachricht 2 von 2
SteveKStafford
als Antwort auf: Anonymous
It is likely a network connection issue or the file is busy (being opened at the same moment, in the middle of a sync). I find that if I wait a minute or two and try again the file usually is opened. If it continues to pop the warning get IT involved to confirm the network is up, working normally.
Steve Stafford
