New to Revit & want to install it on my Mac Book.
Question : Will the spec handle Revit?
RAM : 16GB
Hard Drive : 750GB HDD
Gelöst! Gehe zur Lösung
Gelöst von Jacob.westergaard. Gehe zur Lösung
Hi @Anonymous,
actually the lastest version is the most performing one, which means that will optimize everything that your Mac has as its power.
If you could create a Windows partition you would achieve better performance.
I think that Revit will run on it.
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Thanks for reply.
Just to give you all extra info :
Any further input would be much appreciated.
You will be able to run it.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi John,
Thank you for posting this on the forum,
I would agree with Nicola you should be all good - I would want to direct you to our System Requirement pages where you can check compatibility and minimum requirements for Revit to run. Links below:
Best Regards,
