Revit Callouts Section Bubbles Not Showing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
mhaschakHSE
22497 Aufrufe, 4 Antworten
Callouts are set to on in my visibility settings and when I create a new callout the bubble doesn't appear after I set the area.
I am looking to add the section bubble to the attached callout area. How do I go about getting this added?
4 ANTWORTEN 4
Nachricht 2 von 5
Revit_Whisperer
als Antwort auf: mhaschakHSE
I am guessing that there is not a Callout Head associated to the Callout.  If you go to the Manage tab, Additional Settings, Callout Tags you can assign a Callout Head to the family.  You will need to load a Callout Head type before you can assign one.
Nachricht 3 von 5
tuuletin
Also, you can select the callout border, click "edit type" on the properties palette and check, whether a family is assigned to the callout header or not...
Nachricht 4 von 5
I have the opposite problem, I need to hide the callout bubble and cannot.
Nachricht 5 von 5
als Antwort auf: Anonymous
@Anonymous
Do you want to hide the entire callout boundary and its bubble or just the bubble?
