I am trying to calculated the girth (perimeter) of pile caps within the Structural Foundation Schedule in order to calculate working space & formwork with no luck.
Any advise greatly appreciated.
if I understand you well you want to make a sum of all shuttering area of the pile caps. That means only the side areas of these concrete blocks.
I t can be done in schedule by using formula , as in my screenshot.
Constantin Stroescu
and you have to check Calculate Totals from Formatting in order to calculate the sum of all shuttering areas:
Constantin Stroescu
Thanks Constantin, This works for rectangular or square pile caps, but not for triple or irregular shaped caps.
Why not? The formula is the same.
