Revit Bluebeam plugin is no longer working with BIM 360 projects since we installed Bluebeam 18.5.0. We get an error. Is anyone else seeing this problem?
This plugin assists with printing to PDF from Revit in a custom and organized order.
Picture of Error popup and plugin list attached.
Solution:
Under the Folder Options button from the plugin window.
"Source Folder" feature option is not working.
Choose "Custom Projects Folder" instead and the plugin will work.
Hi all,
Thank you for your help. After selecting a custom project folder, the 3d PDF still does not show. Any other possible solutions found?
