Recently all my revit programs are showing blank screen on all my views. The elements are there and
when I print it all shows up. Please need help on this..
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Done that. Originally I work on white background. nothing on all the views.
In addition to what Toan suggested-
-Does this happen on all projects? Try starting a new project?
-Do all users have this? Did you reboot/restart your PC?
Is this a post-rendering issue? I've had this happen before. But it isn't "stuck" per se. I can fix it pretty quickly -- and without using a hammer or duct tape.
Hi @Anonymous
Clear your temp folder, repair Revit, and reboot/ relaunch and let me know if it still persists.
Also, check your task manager - if you have Trend Micro - OfficeScan Virtual Endpoint Security Protection- that may be blocking the licensing process in the background and the program hangs resulting in a blank background. Switching it off resolved the issue in some instances.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
i had the same problem, and after reading this thread tried some of the solutions. i will add that im using a laptop, and the reboot computer option didn't work. what worked for me was turning off the hardware acceleration, and leaving it off as i rebooted the program.
this is actually the solution that worked for me as well, quick and easy
