Revit backups causing conflicts in cloud storage revisioning
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
nathaniel.mcmahon
369 Aufrufe, 1 Antwort
Hi all,
We're using sharepoint to manage our CDE and are having issues with revit backups and would rather do without them or send them somewhere else.
If a .0001 backup is synced to the cloud it replaces the original and the updated (original filename) file is a new file losing all metadata stored in the cloud. (the backup now has the metadata)
I'm guessing this is because the file is exactly the same content as the previous so the cloud just recognises a name change and does so. the imports the existing file as an update.
Anyway it's causing chaos. Any ideas?
1 ANTWORT 1
Nachricht 2 von 2
I've found an addon below that allows you to move the backup location or stop them completely
https://apps.autodesk.com/RVT/en/Detail/Index?id=2121364206361622178&appLang=en&os=Win64&autostart=t...
