Revit automatically closes when opening Dynamo
8 ANTWORTEN 8
Nachricht 1 von 9
814 Aufrufe, 8 Antworten
hey guys, please help me resolve this issue. As told above, my revit 2017,2018,2019 automatically closes when I open any versions of Dynamo or created new Dynamo project. Icon Dynamo files become white in window folder. I have removed and reinstalled both of Revit and Dynamo but not useful. Any help is respectful!
8 ANTWORTEN 8
Nachricht 2 von 9
sureshchotrani
als Antwort auf: Anonymous
Hi @Anonymous
Can you please apply the latest updates for one of the version and see if that helps?
Kindly install the Revit 2019.2 update and let us know how it goes.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Nachricht 3 von 9
als Antwort auf: sureshchotrani
hi @sureshchotrani . I've just updated 2019.1 but doesn't help.
Nachricht 4 von 9
sureshchotrani
Kindly help with journal file, details on the journal file can be found at https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 5 von 9
https://drive.google.com/file/d/1c2WB3KLWRjlbc27M_he4a0JZ1FuABGYC/view
Here is my Journal Files on 01.03.2019 the day when it has happened
Nachricht 6 von 9
sureshchotrani
Can you please remove the V Ray Plugin and check if that helps?
Journal also shows that you are on Revit 2019.01 the latest build is Revit 2019.2
Kindly install via manage.autodesk.com, once login you will find the updates under Revit.
See here on how to remove the addins, https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 7 von 9
I’ve just removed all things Revit, add-ins and Dynamo and reinstalled them. It’s seem better, revit doesn’t close when opening Dynamo, even it’s available to create new project, but still persisting issue in the images that I provided above “Error opening corrupted file:D:\…”, all icon of dynamo files still white, some of them could be open, and some of them couldn’t! I installed the last version of Dynamo 2.0.2.
Nachricht 8 von 9
sureshchotrani
It looks like the issue is with Dynamo, will request you to ask the same at Dynamo Forum https://forum.dynamobim.com/
Nachricht 9 von 9
thank you @sureshchotrani !
