We are looking to have a team with multiple Microsoft Surface, they will be using Autocad and Revit on remote desktop on a server not on the tablet.
they will be 5 to 10 in same time using this local remote server.
We are looking to know what would be the best specification needed without any lag for 10 person working on same PC,
All Microsoft surface will not have autodesk product installed they all use is ur local account logged to a local remote server that this one will have autodesk product,
We are looking to know what is the best performance needed for this,
how many ram memory, cpu ghz, best gpu needed if needed has they are all on remote desktop.
thanks you very much for your help!
Gelöst! Gehe zur Lösung
Gelöst von DarrenP. Gehe zur Lösung
Have a look at this article. Remote Desktop Services isn't mentioned, so I guess that's not possible?
system requirements are here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/System-requirement...
you can't really guarantee that you won't experiance lag on anything you put together either a system in a cloud or a local system in your LAN
DarrenP
cause its not hardware there are other factors that can affect performance
read these:
what are you running revit on now?
DarrenP
there is system requirement for VM Ware requirements in the link above see below
this should give you a starting point
| Revit® 2024 Revit® LT™ 2024 VMware®: Recommended-Level Configuration³ |
| VMware Software |
| Virtual Machine Operating System | 64-bit Microsoft Windows 10 Microsoft Windows 11 |
| Host Server Recommendation | Performance4 |
| CPU | 3.0 GHz+ Intel® Xeon E5 or later; or AMD® equivalent. |
| Memory | 384-512 GB |
| Networking | 10 GB |
| Storage | ~750+ IOPS Per User |
| GPU | NVIDIA® GRID (K260Q or later) or AMD MxGPU (Radeon Pro V340 or later) |
| Virtual Machine Settings | Performance4 |
| Memory | 16-32 GB RAM |
| vCPUs | 8 vCPUs |
| Disk Space | 30 GB free disk space |
| Virtual Machine Connectivity | Internet connection for license registration and prerequisite component download. |
| User Access | Each client computer should have the VMware Horizon Client installed. |
DarrenP
each person will need to have their own Autodesk Account
DarrenP
this is something you need to ask your IT dept or your VM ware specialist
DarrenP
