Revit + Autocad causing GPU clock to spike
0 ANTWORTEN 0
Nachricht 1 von 1
a_paynter
212 Aufrufe, 0 Antworten
Hi there,
so i've just noticed some unusal behaviour with my GPU in regard to using Autodesk products.
I usually use Revit in conjuction with Autocad on a 3 monitor setup. With all 3 monitors turned on, my GPU clock stays at base levels as it should.
In the past, using Revit + Autocad and even Sketchup never causes the GPU clock to up from this, however now i'm just noticiing that the when using either of the forst 2 programs, the GPU clock is spiking up to load levels, as though i were gaming or rendering.
This is new, seemingly random behviour, it was working as it should after the recent Nvidia update, and now all of a sudden, out of the blue without chaning anything in the system, the GPU is spiking up when using those Autodesk products.
Ive tried a clean driver install using DDU but the problem persists, try turning off Hardware acceleration in both programs, nothing doing.
Any ideas?
0 ANTWORTEN 0
