revit architeture file closes
niranjala
niranjala
Hi
Recently my computer at work was upgraded.
Since then, if I work in a hurry, the screen goes black and gives an error message 'hardware acceleration disabled'.
Then when I cheked with options it says, 'revit has not been tested with the graphic card NVIDA GeForce GTX 960'.
Today it happened 4 times over 1 1/2 HRS.
This is frustrating as I have a lot to finish with the project.
 the error message are attched
R
Nira
LisaDrago
For your video card - make sure the video driver is on the latest release.
That is the first thing I would check.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
niranjala
thanks, i'll try.
i went thro autodesk site and found that the graphic card i'm using is is not yet tested for revit.
ennujozlagam
Hi Just to follow up to Lisa Drago suggestions. maybe you can try to read here. hope it helps. thanks.
http://forums.autodesk.com/t5/revit-architecture/revit-2014-on-windows-8-1/td-p/4958654/highlight/tr...
